automatically Import and sync Addresses in global company phonebook
Discussion in 'CRM / Helpdesk / App Integration' started by bsc-computer, Feb 8, 2018.
  1. bsc-computer
    Sep 29, 2017
    15.5 / Windows
    we are looking for a way to automaticly import address data in the global company phonebook.
    Via Phone System Manager only manually import is possible.
    (And only 1000 addresses at one time :-( )
    Also ODBC is no solution because data will only appllied for incoming calls.
    How to import address data automatically ?
    We are able code a tool create a CSV-File or directly access a database.
    But how?
    Any suggestions?
    Reinhard
    #1 bsc-computer, Feb 8, 2018
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,078
    77
    Hello Reinhard,
    You can use the 3CX Call Control API to do that from a C# program running in the 3CX server:
    https://www.3cx.com/docs/call-control-api/
    Take a look at the PhoneBookEntry class, which is what you need to use here.
    Kind regards.
    Ernesto.
