Automatically Schedule your 3CX Backup
Discussion in '3CX Phone System - General' started by ziptalk, Aug 17, 2009.
  1. ziptalk
    ziptalk New Member
    Nov 16, 2008
    180
    Here is a short batch file script you can schedule using Task Scheduler to backup your 3CX using the 3CX Backup Utility. This script will generate a new backup file eachtime it is run, by virtue of the %random% value that ensures the file name is unique. Note, the random function is basic, but it'll suffice for my requirements, and that is daily snapshot backups, particularly as I am editing the configuration on a regularly basis as I learn more about the system and implement features and soforth.
    Backup.bat - Sample Code for automated scheduled backups to generate unique filename and not overwrite existing backup
    Code:
    cd C:\Program Files\3CX PhoneSystem\Bin
    3CXBackup backup C:\3CX_Backup\3cxbackup%random%.zip /call history /prompts /recordings /exit
    I would dump some more screenshots in, but it's late, and I trust everyone is accustomed to setting up a task in task scheduler and creating a .bat file in notepad.
    Hope that's useful. Lewis
  2. WINWARE
    Nov 30, 2007
    29
    What version of 3CX backup are you using? I am using v7.1.6589.0.
    When I run a 3CXBackup.exe /? I get the switches are:
    /callrecordings
    /voicemails
    /voicepromts
    /callhist
  3. WINWARE
    Nov 30, 2007
    29
    Also, Does this stop the 3cx services to do the backup?
  4. ziptalk
    ziptalk New Member
    Nov 16, 2008
    180
    doesn't stop the services, it's a live backup, i have one running mid-day and no issues on the phone system which is live.
    I'm running 7.1.7139.0
    If you check the manual it shows all the switches, I think I saw the /exit there to close the gui on completion.
    Hope that helps, Lewis
  5. tpinnovations
    tpinnovations Member
    Jul 30, 2009
    296
    Correct me if I'm wrong, But don't you need to make sure you have volume shadow copy enabled to prevent file corruption?
  6. johnb
    Sep 21, 2009
    Apparently the option switches have changed. I use the following:
    REM set todays date as variable - NOTE this only works for UK dates - change for other date layouts
    SET TODAY=%date:~6,4%-%date:~3,2%-%date:~0,2%
    "c:\program files\3cx phonesystem\bin\3cxbackup.exe" /hidden backup Z:\3cx_backups\%today%.zip /callrecordings /voicemails /voiceprompts /callhis
    This runs backup hidden and automaticaly exits on completion. Each filename is date of backup.
  7. pjr
    pjr New Member
    Oct 5, 2009
    154
    Hi John - thanks for that - works like a charm!
    Paul
  8. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,399
    79
    Here's my Working solution for it.
    And it's Fully Automated.
    You can Change the Program Files Path if you are using 64Bit / 32Bit Machines.
    You will have to make a Folder Called 3CXBackups in your C:\ Directory first so all the backups will go there.
  9. stash
    stash New Member
    Feb 23, 2012
    213
    Sir john,
    How can i include the firmware on the backup :D and changed the %today% filename to be the date todya?
    Thanks,
    STASH
  10. gschwab
    gschwab New Member
    Mar 21, 2012
    131
    Lets not forget that in the event of a hard drive failure (your most likely reason for data loss) these backups are useless if stored on the same drive as 3CX. At the very least you should make a backup of your working installation to a CD or DVD. I personally do a tape backup of the server every night and take the previous nights backup off premises that way should there be a failure or worse yet a theft or fire I simply get a new computer, restore the whole thing and be up and running.
    George
  11. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,947
    179
    Add a USB drive so at least it's on a separate medium...
  12. igadmin
    Jun 19, 2012
    You can also create a "Dated" backup instead of a randomized named backup.
    I'm using this script which gives me backup files with <today's date>.zip
    @echo off
    cd "C:\Program Files\3CX PhoneSystem\Bin\"
    set today=%date:~-4%%date:~4,2%%date:~7,2%
    3CXBackup.exe backup C:\3CXBackup\3CX.%today%.zip /callrecordings /voicemails /voiceprompts /callhist /firmware /exit
    SET today=
    exit
  13. craigreilly
    Feb 1, 2012
    2,947
    179
    and you can use the forfile utility to get rid of "x" # of files.
    I keep 5 days
    forfiles.exe /p F:\ /s /m *.zip /d -5 /c "cmd /c del @path"
  14. grapevine
    Nov 4, 2011
    I have been trying to get the automatic back-up to work on version 11 and have now sorted it...with help.
    I am running this on Windows 7 Pro (64-bit).
    > Use the following to create a batch file:
    @echo off
    echo Running Configuration Backup...
    "C:\Program Files\3CX PhoneSystem\Bin\3CXBackup.exe" hidden backup "(Specify the path here that you want to save to)\config_backup.zip" /exit
    echo Running Data Backup...
    "C:\Program Files\3CX PhoneSystem\Bin\3CXBackup.exe" hidden backup "(Specify the path here that you want to save to)\full_backup.zip" /callrecordings /voicemails /voiceprompts /callhist /exit
    > Save that file to the C:\ drive
    > Give administrator rights to the 3CX Backup and Restore Utility
    > Open Windows Task Scheduler
    > Create a new file by right clicking on the Task Scheduler Library and name it 3CX
    > Create a new task in here and use the batch file that you saved to the C:\ drive.
    > Set the task to run as often or as little as required.
    This will now create a full backup (VM ect..) and a config backup which is your base config.
    Hope this helps as I had to spend a bit of time on it getting it right.
  15. craigreilly
    Feb 1, 2012
    2,947
    179
    You should also consider backing up to a Thumb Drive or external hard drive if you are on a small machine (non server grade [no raid]).
    Also, I recently had some issue getting the backup to run when not logged in, and I found changing the user to "Administrators" (the group) that it worked.
  16. PCTurnkey
    Mar 26, 2012
    31
    Thanks guys. The BackerUpper didn't work for me, but used the first post to create a .bat file. Changed it so it backed-up on server and locally.
    Works like a charm!
  17. PCTurnkey
    Mar 26, 2012
    31
    Here's what I used (created in notepad, filename: 3cxBackup-Local.bat):
    3CXBackup backup E:\Backup\3CX\3cxbackup%random%.zip /call history /callrecordings /voicemails /voiceprompts /callhist /prompts /recordings /exit
    #I think the last two are redundant, but I checked the zip file it created and it has everything I needed stored. File size is about 5.80MB (don't know if that's really low since my setup is relatively new, or average for 10 extensions).
  18. Denzeltpa
    May 3, 2012
    @Grapevine, Thanks it worked great. Does the full backup include the full system config? I haven't gotten into the manual to really check how it runs and with what switches.
    Also, I put the backup into a mapped network drive and into dropbox. I always have an offsite copy.
