Automatically sending to survey after call
Discussion in '3CX Phone System - General' started by jakko, Mar 31, 2014.
  1. jakko
    Mar 31, 2014
    Hi. We are close to making a decision on purchasing a 3cx system and have one final requirement that I cannot seem to find an answer to. We would like the ability to send a call to a post-survey after the rep is done speaking to the customer. It should be automatic and not requirement anything action by the rep to send the customer to the survey. Are there any modules that support this feature?
    Thank you!
  2. jakko
    Mar 31, 2014
    Really need to know if this is possible. Even if you think it's not, please let me know. Thanks!
  3. 12494
    12494 Member
    Apr 16, 2010
    306
    31
    I am not familiar with a way to make this automatic. I think the rep would just have to forward the call to the survey. I would think you could set up a DSS key on a phone to do this with a single button push if it was too much work to actually go through the transfer sequence - or you could to it from the Windows workstation client.
    Allen
  4. carolinainnovative
    May 4, 2009
    369
    6
    I would think you could do this with some work via the 3CX VAD or perhaps a custom CRM integration. The phone system by itself will NOT do this - but with some additional magic, you could certainly make it work.
  5. CentrexJ
    CentrexJ Member
    May 5, 2009
    458
    75
    Contact the folks at VoIP Toys. They have lots of add-ons for 3cx. If they don't have something exactly what you want you might be able to get them to quote you on what it would cost for them to custom build you the product.
    https://www.voiptoys.com/
