Automatically Try to Register
Discussion in '3CX Phone System - General' started by Anonymous, Oct 19, 2006.
  1. Anonymous
    Anonymous Guest
    Is there a setting that will cause the server to reset, or retry registering with a carrier if the line drops? For some reason my windows pc keeps losing the registered status for one reason or another.
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    2,004
    308
    Reregister
    Unfortunately there is not. The reregistration has to come from the client.
    It would be a great feature to have, we will look into making a work around.
  3. Anonymous
    Anonymous Guest
    2 Stages of Implementation
    • I guess if it was possible it should work that the server will continue to try to register with the carrier if possible. A flag with a timer to retry should be easy enough. It would be a matter of triggering the same function that is triggered when you press the okay button after setting up a VOIP line and Gateway.
      Subsequently have the client with the same setup would make that advantageous; that way someone doesn't miss important calls while working on a spreadsheet or standing at a whiteboard.
  4. Nick Galea
    Jun 6, 2006
    2,004
    308
    Configure re-registratino
    Well you can configure more frequent registration in the phone or SIP software client, just as the IP PBX can be configured to re-register more frequently with the VOIP provider.
    However it has to be configured at the client end.
  5. Anonymous
    Anonymous Guest
    HOWTO from a HOWDO
    Thanks for the answer.
    For those of you like me:
    HOWTO Register Server More Frequently
    1. Under the lines menu click on <Manage>
    2. Click the hyperlink of the name of the Gateway you want to configure.
    3. Change the "Time between registration attemps (in seconds)"
    *Note: 3600 is 1 hour.
    I changed mine to 300 so I am wondering what the downside is; otherwise, why not set it to 1 minute?
  6. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Re: HOWTO from a HOWDO
    The only downside is the increasing of network traffic. But for home or small office network - it's not noticeable at all.
