Automation of the extension and user administration
Discussion in '3CX Phone System - General' started by Voipist, Feb 19, 2018.
  1. Voipist
    Feb 19, 2018
    12
    is there a 3cx api with which you can create user and extensions? Is there a way to query the Provisioning Link from the database or geht it via api
  2. voiptoys
    voiptoys Member
    Feb 13, 2013
    467
    79
    Yes, you can create extensions using the 3CX Call Control API. I assume you are referring the terms "users" and "extensions" to mean the same thing.
    The provisioning link is a property you can also query from the API, but understand that in 15.5 the provisioning "files" are generated on-the-fly and "streamed" to the phones. Therefore, you cannot access the provisioning data via the API because the data doesn't exist except briefly when the phone requests it's provisioning information, and even then only in memory.
