Autoprovisioning bug
Discussion in '3CX Phone System - General' started by Pentangle, Jan 28, 2008.
  1. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    Hi there,
    I think i've found a bug in autoprovisioning.
    I have a Snom320 and have just autoprovisioned it, but the message retrieval button tries to ring 999 (i.e. the old hardcoded message number) instead of the number assigned to "Special Voice Menu Extension Number". This is obviously a problem, as 999 is the UK emergency services :)
    Can this be fixed please.
    Cheers,
    Mike.
