- Joined
- Dec 11, 2006
- Messages
- 363
- Reaction score
- 0
i have tested autoprovisoning on GXP-2020 now and found out that the phone can call other extensions but can not be reached by other extension.
setup
3CX Phone System Version5.0.3790.0 on public IP
2 Grandstream GXP-2020 on a other fixed ip behind nat router
first self set up with fw 1.1.4.17 (ext 200)
second auto provisioned with fw 1.1.4.17 (ext 210)
!!!!!! A ver special behavia is if i call with ext 200 to 210 i first get no reaction and after some time ext 200 give me a (is ringing tone) and the linestatus screen in the console tells me that it do a outcall over voip line 10003 (sipgate)
Time Function Message
16:53:33.876 Call::Terminate [CM503008]: Call(80): Call is terminated
16:53:24.095 Line:rintEndpointInfo [CM505003]: Provider:[0211580098011 SIPGATEde] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:99.88.25.24:5060]
16:53:24.095 CallCtrl:nAnsweredCall [CM503002]: Call(80): Alerting sip:[email protected]:5060
16:53:23.298 MediaServerReporting::SetRemoteParty [MS210002] C:80.3:Offer provided. Connection(transcoding mode): 99.88.25.24:9004(9005)
16:53:23.095 CallCtrl:nRerouteReq [CM503005]: Call(80): Forwarding: VoIPline:10003@[Dev:sip:[email protected]:5060, Dev:sip:[email protected]:5060, Dev:sip:[email protected]:5060, Dev:sip:[email protected]:5060, Dev:sip:[email protected]:5060, Dev:sip:[email protected]:5060, Dev:sip:[email protected]:5060, Dev:sip:[email protected]:5060]
16:53:22.813 CallLeg:nFailure [CM503003]: Call(80): Call to sip:[email protected] has failed; Cause: 408 Request Timeout; internal
16:52:50.626 MediaServerReporting::SetRemoteParty [MS210006] C:80.2:Offer provided. Connection(by pass mode): 87.230.126.104:11956(11957)
16:52:50.423 CallCtrl:nSelectRouteReq [CM503004]: Call(80): Calling: Ext:210@[Dev:sip:[email protected]:5060;transport=udp;user=phone]
16:52:50.423 CallCtrl:nSelectRouteReq [CM503010]: Making route(s) to [sip:[email protected];user=phone]
16:52:50.423 MediaServerReporting::SetRemoteParty [MS210000] C:80.1:Offer received. RTP connection: 87.230.126.104:11956(11957)
16:52:50.423 CallLeg::setRemoteSdp Remote SDP is set for legC:80.1
16:52:50.423 Extension:rintEndpointInfo [CM505001]: Ext.200: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXP2020 1.1.4.17] Transport: [sip:99.88.25.24:5060]
16:52:50.407 CallCtrl:nIncomingCall [CM503001]: Call(80): Incoming call from Ext.200 to [sip:[email protected];user=phone]
16:52:50.204 CallLeg:nNewCall [CM500002]: Info on incoming INVITE:
INVITE sip:[email protected];user=phone SIP/2.0
Via: SIP/2.0/UDP 192.168.178.235:63466;branch=z9hG4bK92ecd2dc4499a379;rport=63466;received=87.230.126.104
Max-Forwards: 70
Contact: [sip:[email protected]:63466;transport=udp;user=phone]
To: [sip:[email protected];user=phone]
From: "A Ittermann"[sip:[email protected];user=phone];tag=048ef217ad9dc60c
Call-ID: [email protected]
CSeq: 32656 INVITE
Allow: INVITE, ACK, CANCEL, BYE, NOTIFY, REFER, OPTIONS, INFO, SUBSCRIBE, UPDATE, PRACK, MESSAGE
Proxy-Authorization: Digest username="200",realm="3CXPhoneSystem",algorithm=MD5,uri="sip:[email protected];user=phone",nonce="12844540369:d34d0e021195d6880bd5f0fa46a7c80e",response="5715282f69cf0c80042e288795bf3127"
Supported: replaces, timer, path
User-Agent: Grandstream GXP2020 1.1.4.17
Content-Length: 0
i don´t know why this happens until now but i wil change the setting and try to find out . (SOLVED NOW - READ ON)
if i try to reach ext 211 (what is not existing) i get
404 error and that is correct.
Andy
setup
Max-Forwards: 70
CSeq: 32656 INVITE
Content-Length: 0
Andy
