Avaya 1608-I IP Phone Support
Discussion in '3CX Phone System - General' started by tangsuan, Nov 21, 2016.
  1. tangsuan
    Nov 21, 2016
    Hi Person in-charged:
    My company is using 3CX V15 VoIP Phone system.
    Right now, I am trying to setup Avaya 1608-I IP Phone to work with 3CX. My questions here are:
    1. Is the 3CX can use with Avaya 1608-I phone?
    2. If yes, how to setup the phone?
    Thanks!
    Regards,
    Tangsuan
  2. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    220
    First, it should have SIP firmware, not H.323
    Second, I really doubt this will be possible
