Avaya 9650/9620
Discussion in '3CX Phone System - General' started by coertvc, Aug 23, 2014.
  1. coertvc
    Jan 23, 2014
    26
    all,
    After wrestling a long time with my 9650 and 9620 phones I seem to be at a stage where it is working, short summary;
    Avaya 2.6.12 firmware, 2008R2 server, no Vlan's
    Issues I had were;
    - every second call attempt was wrong; solved by leaving the password of the extension in the 3cx server empty (not a real solution i will have to admit, bu to be continued)
    - no audio now and then; the reserved reg key change on windows server 2008/2012 will NOT work, I had to apply a non-mainstream fix from MS (article attached) and that did it
    - contacts are still not working, so will work if I can connect it to exchange or work around with dummy backup files
    - language pack outside English not working: I had to put and extra reference to an other language pack before and after the LP i want to use. (see in bold below)
    The config file
    SET DNSSRVR 192.168.200.8
    SET SIP_CONTROLLER_LIST 192.168.200.9:5060;transport=tcp
    SET CONFIG_SERVER 192.168.200.9
    SET SIPPROXYSRVR 192.168.200.9
    SET SIPDOMAIN 3cx.xxx.xxxx
    SET REGISTERWAIT "900"
    SET SPEAKERSTAT "2"
    SET PHNNUMOFSA "3"
    SET ENABLE_AVAYA_ENVIRONMENT 0
    SET SIPPORT 5060
    SET DSTOFFSET 1
    SET GMTOFFSET +1:00
    SET DSTSTART 2SunMar2L
    SET DSTSTOP 1SunNov2L
    SET SNTPSRVR 85.255.214.66
    SET DISPLAY_NAME_NUMBER 1
    SET SCREENSAVERON 15
    SET BAKLIGHTOFF 10
    SET LANGUAGES Mlf_German.xml,Mlf_Dutch.xml,Mlf_Italian.xml
    SET SYSTEM_LANGUAGE Mlf_Dutch.xml
    SET ENABLE_PRESENCE 0
    SET SIMULTANEOUS_REGISTRATIONS 1
    SET ENABLE_G711U 1
    SET COUNTRY "USA"
    SET PSTN_VM_NUM "999"
    I have tried Grandstream, Cisco and various others, that were (way) easier to configure, but you still can not beat the appearance and feel of an Avaya :)
    next task will be to create a template file for 3CX, wish me luck :)
