- Joined
- Aug 23, 2009
- Messages
- 4
- Reaction score
- 0
Hi all,
Not really a request for help, but just some info to help people trying to get these working with 3CX free edition. I tried using v2.4.1 of the SIP firmware and it slightly unstable so your best going with v2.2 as it seems to work fine (handset has managed to stay logged in for longer than 7 days). My biggest problem was getting the 46xxsettings.txt correct which the phone loads during bootup. Anyway i've pasted a copy below in the hope folks might find it useful.
I'm trying to put an idiots guide together on to re-flash one of these things to get it working, but its a little bit more work than I orginally thought.
## This is the webserver you tell the phone to download the 46xxsettings file from in the future
SET HTTPSRVR 192.168.0.201
## HTTP port on the above server
SET HTTPPORT 80
## Test VLAN
SET VLANTEST 1
## Makes the phone auto login after reboot
SET QKLOGINSTAT 1
## Internal extension number length
SET PHNDPLENGTH 4
## Outside line access number
SET PHNOL 9
## Rest of the dialplan settings
SET DIALPLAN "[1]xxx|[4]xxx|[5]xxx|[6]xxx|90xxxxxxxxxx"
## These settings just lock down the menus on the phone - The settings below give you full blown access
SET APPSTAT 1
SET OPSTAT 111
SET PROCSTAT 0
SET PROCPSWD 27238
SET PHY1STAT 1
SET PHY2STAT 1
SET LANG0STAT 1
SET SCREENSAVERON 15
SET GUESTLOGINSTAT 0
SET SPEAKERSTAT "2"
## This setting must be left at0 otherwise the phone logs itself out after 10 mins
SET ENABLE_AVAYA_ENVIRONMENT 0
## Re-register Timer in seconds
SET REGISTERWAIT "300"
## Sip domains
SET SIPDOMAIN "sip.example.com"
SET SIPPROXYSRVR "192.168.0.201"
SET SIPPORT "5060"
## 0 sets it to UDP, 1 sets to TCP, 2 sets to TLS
SET SIPSIGNAL 0
## This field re-affirms what is above but it is needed otherwise you'll get a message saying cant connect to call server
SET SIP_CONTROLLER_LIST 192.168.0.201:5060;transport=udp
## Time & Date settings
SET SNTPSRVR "time.uk2.net"
SET DSTOFFSET "1"
SET DSTSTART "2SunMar2L"
SET DSTSTOP "1SunNov2L"
SET GMTOFFSET "-0:00"
SET SYSTEM_LANGUAGE Mlf_English.xml
SET COUNTRY "UK"
SET DATEFORMAT %d/%m/%y
SET TIMEFORMAT 0
SET DAYLIGHT_SAVING_SETTING_MODE 2
# More full-blown menu settings
SET CALLFWDSTAT "1"
SET ENABLE_SIP_USER_ID 0
SET CNGLABEL 1.
SET PROVIDE_OPTIONS_SCREEN 1
SET PROVIDE_NETWORKINFO_SCREEN 1
SET PROVIDE_LOGOUT 1
SET ENABLE_CALL_LOG 1
SET ENABLE_REDIAL 1
SET ENABLE_REDIAL_LIST 1
SET ENABLE_CONTACTS 1
SET ENABLE_MODIFY_CONTACTS 1
SET ENABLE_MULTIPLE_CONTACT_WARNING 1
PROVIDE_EDITED_DIALING 3
SET PUSHCAP 12222
# Sets Codecs
SET ENABLE_G711A 1
SET ENABLE_G711U 1
SET ENABLE_G726 1
SET G726_PAYLOAD_TYPE 110
SET ENABLE_G722 0
# Enable caller ID - Name & number
SET DISPLAY_NAME_NUMBER 1
# Voicemail settings button
SET PSTN_VM_NUM "1234"
SET MSGNUM 1234
# MWI indicator server - Point this at the 3CX server
SET MWISRVR "192.168.0.201"
SET HTTPPORT 80
## Test VLAN
SET VLANTEST 1
SET QKLOGINSTAT 1
SET PHNDPLENGTH 4
SET PHNOL 9
SET APPSTAT 1
SET OPSTAT 111
SET PROCSTAT 0
SET PROCPSWD 27238
SET PHY1STAT 1
SET PHY2STAT 1
SET LANG0STAT 1
SET SPEAKERSTAT "2"
## Sip domains
SET SIPPORT "5060"
SET SIPSIGNAL 0
SET DSTOFFSET "1"
SET COUNTRY "UK"
SET TIMEFORMAT 0
SET CALLFWDSTAT "1"
SET CNGLABEL 1.
SET ENABLE_REDIAL 1
SET PUSHCAP 12222
# Sets Codecs
SET ENABLE_G711A 1
SET ENABLE_G711U 1
SET ENABLE_G726 1
SET ENABLE_G722 0
SET MSGNUM 1234
