Avaya link
Discussion in '3CX Phone System - General' started by asmith3006, May 28, 2014.
  1. asmith3006
    Mar 5, 2014
    94
    5
    Hi All,
    We currently run an Avaya system in one part of our office and I'm looking and introducing 3CX in another part. I want to be able to transfer calls from one system to the other internally.
    My Avaya guy has setup a SIP trunk and pointed it at my system and I have setup a generic SIP provider and pointed it at his system but I'm not getting anything when I try and transfer over.
    I've made an outbound rule for numbers starting with 7, the digit gets stripped and then it's transferred over the outbound connection but I don't get anything.
    My Avaya guy is telling me everything is right on his end, so where can I start digging to prove which of us has the issue?
    Thanks.
    Andrew.
    10,754
    286
    The problem may be, that both ends, have SIP trunks set-up that are trying to register with one another. One has to behave as a VoIP provider and accept registrations. 3CX should be able to do this with a Bridge trunk set as a Master, that should allow the Avaya to register to it.
    That said...Bridge trunks are meant for use between two 3Cx PBX's, I don't recall seeing a confirmation that it will work with another brand of PBX, but, it's worth a try.
    The alternative would be trying to register the Avaya trunk to a 3CX extension, and vice-versa, which limits your calling options.
