AVG Linkscanner 2012
Discussion in 'Windows' started by thelastphoneguy, Jan 6, 2014.
  1. thelastphoneguy
    Jan 6, 2014
    Just upgraded to 3cx v12 the presence manager does not connect. I called tech support and they suggested I disable AVG. That worked. I then turned on the AVG 2012 internet business modules one at a time. I have narrowed the problem down to the link scanner, specifically the "Online Shield". I have tried everything to to allow an exception to make this work but have had no luck, any help would be great.
  2. 805tech
    Aug 30, 2013
    39
    I had a problem like that. In your settings link scanner or online shield (I forgot which one) you will see exception list. Put your 3CX server IP address and it should resolve your issue.
