Away status keeps changing?
Discussion in '3CX Phone System - General' started by scythe000, Aug 15, 2012.
  1. scythe000
    Nov 8, 2011
    66
    I have an extension, the only one that does this...it automatically seems to change form Available to Custom #1. Any ideas???
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,064
    58
    If using the MyPhone app, look at its settings. It has a feature whereby it will auto change the status of its extension if idle for x minutes.
  3. scythe000
    Nov 8, 2011
    66
    yeah, we're not using that.
  4. lneblett
    Sep 7, 2010
    2,064
    58
    Are you certain that the change is not due to someone inadvertantly using the dial codes to change status?
  5. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,069
    201
    as an option: You could copy the VM folder and the VM Settings (Prompt and Caller ID) for that extension and delete and recreate it... then copy those items back in.
