Babytel CallerID Issue
Discussion in '3CX Phone System - General' started by PatrickMcLean, Nov 27, 2017.
  1. PatrickMcLean
    Nov 27, 2017
    5
    I'm using a Babytel trunk and cant seem to set the From: User Part to anything but AuthID (or blank custom field) or else I can't make outbound calls. I don't want to send my authID as callerID, I want the actual trunk # as callerID.
    Like I can set it to a blank custom field and calls go through as "Unknown".
    Or I can set it to AuthID, which shows my SIP User ID (which is not my Trunk #).
    How do I get it to show Trunk # or nothing at all (Instead of Unknown).
    #1 PatrickMcLean, Nov 27, 2017
    11,117
    329
    I use the Remote Party ID-Calling Party-User Part settings and leave the From: User Part as the AuthID, but, every provider can be different. You might want to ask them, in which field they want to see the outgoing CID number.
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,400
    535
    Hello @PatrickMcLean
    Since calls fail when authId is not present that means the provider requires this for calls to work. Perhaps you can send the AuthID to a different sip field but this is something you have to ask them.
  4. Pierre Menard
    Nov 28, 2017
    Patrick,
    We can apply a permission to allow any callerID on outbound calls, providing you complete a form. Please contact us by phone at 1-877-258-8647 or by email at service@babytel.net and we will proceed with your request.
    Thank you,
    Pierre Menard
    Enterprise Support Supervisor
    http://www.babytel.net/
    service@babytel.net
    Tel: 514-879-8585 X 210
    YiannisH_3CX likes this.
