Backgrounds from URL - Custom Provisioning
Discussion in '3CX Phone System - General' started by mike@amerope.com, Apr 3, 2018.
  1. mike@amerope.com
    Aug 30, 2016
    Every time 3CX updates, it wipes out all of my custom backgrounds and goes back to default.
    I have set up a custom provisioning template.
    I am would like to use a URL that points to the background image such as TinyPic.
    Can someone please tell me how to enter this in the template?
    Thanks!
  2. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    692
    99
    What make and model of phone ? as each phone has different template syntax
    If you look at the template, search for 3CX*.png you probably can work it out. Just modify the code to point to the new file
    Syntax for yealink
    wallpaper_upload.url = %%PROVLINKLOCAL%%/logo/yealinkt48.png
    screensaver.upload_url= %%PROVLINKLOCAL%%/logo/yealinkt48.png
    Files need to be save to C:\ProgramData\3CX\Instance1\Data\Http\Interface\provisioning\xxxxxxx\logo (if windows)
  3. mike@amerope.com
    Aug 30, 2016
  4. mike@amerope.com
    Aug 30, 2016
    yea I know that is what I have been doing.
    I am looking for a way for the custom template to point to a URL of the image hosted on the web.
  5. Saqqara
    Mar 12, 2014
    692
    99
    Just change %%PROVLINKLOCAL%%/logo/yealinkt48.png to the full url on the picture you want.
  6. Saqqara
    Mar 12, 2014
    692
    99
    Custom templates are not overwritten on updates, only 3CX standard templates
  7. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,794
    131
    you can't have it both ways...
