backing up a callflow
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, Jul 9, 2010.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    With version 9, wil IVRs backed up with the backup tool now successfully restore? Or will you have to re-deploy a VAD IVR after someone runs a restore from the backup/restore tool?
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    The latest build solves that issue. Check the release notes here:
    http://www.3cx.com/blog/releases/3cx-phone-system-v9-rc1/
    Regards,
  3. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Awesome.
    So I could get a backup copy of a system and always deploy on the local development machine, and then backup again and it could be redeployed to the production machine through a restore.
  4. VAD_Support
    Aug 6, 2009
    690
    Yes, but be careful because you would be restoring everything, not just the VAD callflow. So, for example if you create an extension in the production environment, you could restore a system from development where the extension has not been created, you will be deleting the new extension from production...
  5. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    There's a great potential feature then. Being able to restore just that extension.
    Or more simply put, if the backup/restore tool could restore in APPEND mode to 3cx.
  6. VAD_Support
    Aug 6, 2009
    690
    Yes, that would be a useful feature to have in 3CX!
