Backup and restore
Discussion in '3CX Phone System - General' started by gpetrom, Oct 20, 2007.
  1. gpetrom
    Oct 12, 2007
    16
    Ok i am new in 3cx and i want to ask some questions
    Can i schedule a backup task with 3cx or can i backup 3cx from command line?
    Can i record some calls if i want in some extensions?
    Can i some how connect to the database that 3cx use to store the logs so i
    can make custom log reports?
    And if no will it be possible in ver 4.0
    Thanks all in advanced
    Sorry if my english are bad[/u]
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    It should be both are not support.
    The current version (3.1 Build 2434) support manual backup by click Backup and Restore at General Tab
    It should be Not support as well.
    You can install psqlODBC for access the database. Refer to http://www.3cx.com/forums/categories-1/feature-requests-5/odbc-conectivity-2216/
