Backup - Built in FTP Server
Discussion in 'Ideas' started by solutionsit, Dec 18, 2015.
  1. solutionsit
    Nov 25, 2014
    62
    5
    On our deployments we have a backup to USB.
    This is done by having a ftp server installed on the pbx and then point it to a usb drive.
    Could this be built into 3cx so it doesn't have to be a extra setup step of installing a ftp server.. to be able to save it to a removable drive.
    I guess the end result would be to have the option to save it to usb as a destination.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,544
    298
    I write a BAT file to copy the files to USB.
    Copy the current backups in the system folder to the usb and overwrite existing files.
    I run this about an hour after the 3cx backup is set to run - as my install is small and only about 50mb backup.
