Backup Config Security
Discussion in 'Ideas' started by David Mactaggart, Jan 22, 2016.
  1. David Mactaggart
    Jun 19, 2015
    Can I suggest that you add in some form of encryption/password on the backup ZIP file so that all passwords aren't easily accessible from the stored XML file in there. Or include some form of option not to store passwords in plain text.
