Backup config without license information - Clone CFG
Discussion in 'Ideas' started by aceltic, Jan 25, 2016.
  1. aceltic
    Jan 18, 2016
    9
    It would be great if we could backup a complex pbx configuration for clonation purposes. The actual problem now is that the restore activates the backup license just after restart.
