Solved Backup Failure
Discussion in '3CX Phone System - General' started by phil@lgmanor.com, Feb 3, 2017.
  1. phil@lgmanor.com
    Oct 13, 2016
    28
    Version 15 - Windows Server 2012 R2 - 8GB memory
    Have had no problems with backups before. For the last few days have had a backup failure with the following message.
    3CX Phone System tried to backup but failed due to the following reason(s):
    System.Exception: Error creating backup ---> System.AggregateException: One or more errors occurred. ---> Npgsql.NpgsqlException: The connection pool has been exhausted, either raise MaxPoolSize (currently 100) or Timeout (currently 600 seconds)
    at Npgsql.ConnectorPool.<WaitForTaskAsync>d__24.MoveNext()
    --- End of stack trace from previous location where exception was thrown ---
    The back up file is not very large, there is 500GB of disk space available. Have cleared temp files, and rebooted.
  2. GiannosC_3CX
    GiannosC_3CX Guest
    Dear phil,
    Please disable your schedule backup, next enable verbose mode on activity log settings, after restart your services and then enable the schedule backup again and let the system to run the schedule. Please let us know if this error still received.
  3. phil@lgmanor.com
    Oct 13, 2016
    28
    Still no go. Rebooted Server, ran windows updates, normal temp file cleanup. Manual backup works as expected.
  4. orion
    Mar 18, 2009
    We also have a 3CX v15 server with all current updates which started showing the exact same error on Friday nights scheduled backup.
    Server 2012 R2 with 8Gb RAM running on VMWare 5.5.
    Backup works fine manually.
    Backup size is 1Gb.
    Regards
    Rob
  5. IT Admin
    Feb 6, 2017
    Same here and issue first occurred on Friday night.
    Running v15.0.59950.0 on Server 2012 R2 with 8Gb RAM, Manual backup works fine.
    Backup size is 136 MB
  6. GiannosC_3CX
    GiannosC_3CX Guest
    Hi there,
    What scheduled backup do you use? (weekly or daily)
  7. IT Admin
    Feb 6, 2017
    Daily
  8. 7networks1
    Apr 4, 2016
    Hello there,
    same problem here on version 15.0.59381.0 on Win 2012 R2.
    Manual Backup works just fine, scheduled (daily) one stopped working January 26. Backup size is just 111MB.
  9. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,344
    535
    As a first step upgrade to the latest service pack and try scheduling the backup again. Let us know if that works
  10. GiannosC_3CX
    GiannosC_3CX Guest
    Hi there,
    Also, please try with weekly schedule and let us know if the problem persists.
    #10 GiannosC_3CX, Feb 8, 2017
  11. Brett Garfitt
    Feb 10, 2017
    14
    Running v15.0.59950.0 and having a similar issue with daily backups about once a month or so.
  12. GiannosC_3CX
    GiannosC_3CX Guest
    Hi Brett,
    Please upgrade to the latest service pack ( 15.0.60903.0 )and try scheduling the backup again. Let us know if that works
  13. orion
    Mar 18, 2009
    Already running the latest version here and still receiving the backup error.
  14. GiannosC_3CX
    GiannosC_3CX Guest
    Hi Orion,
    Are you on version 15.0.60903.0 ?
    Also please try to change from weekly to daily and vise versa.
    Please let us know if still receiving the backup error on both cases. (weekly or daily)
  15. GoPiTM
    May 15, 2015
    9
    We have the same problem
    I switched from a daily to a weekly but this did not work.
    Daily error:
    Code:
    at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
    at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
    at Npgsql.ConnectorPool.<AllocateAsync>d__0.MoveNext()
    at Npgsql.NpgsqlConnection.<OpenInternalAsync>d__0.MoveNext()
    at _3cxNetInterfaces.Implementation.Npgsql.NpgsqlDbOperation.<CreateConnectionAsync>d__26.MoveNext()
    at _3cxNetInterfaces.Implementation.Npgsql.NpgsqlDbOperation.<BeginTransactionAsync>d__36.MoveNext()
    at _3cxNetInterfaces.Implementation.Npgsql.NpgsqlDbOperation.<BeginTransactionAsync>d__35.MoveNext()
    at _3cxNetBackupAndRestore.BackupTasks.BaseDBTask.<RunAll>d__12.MoveNext()
    --- End of inner exception stack trace ---
    at System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions)
    at System.Threading.Tasks.Task.Wait(Int32 millisecondsTimeout, CancellationToken cancellationToken)
    at _3cxNetBackupAndRestore.BackupTasks.MyPhoneTask.<.ctor>b__0_0(BaseTask x)
    at _3cxNetManagement.BaseTask.Run()
    at _3cxNetBackupAndRestore._3cxBackup.WaitForFinish()
    at _3cxBackupRestoreImpl.BackupRestoreUtils.Backup(String instanceId, String cfgPath, String dbConnectionString, BackupConfig options, String fullpathFilename, NetworkCredential credentials, Boolean sendEmail)
    at BackupRestoreSchedule.BackupJob.Execute(IJobExecutionContext context)
    Weekly error:
    Code:
    at _3cxNetInterfaces.Implementation.Npgsql.NpgsqlDbOperation.<BackupTableAsync>d__27.MoveNext()
    at _3cxNetBackupAndRestore.BackupTasks.BaseDBTask.<>c__DisplayClass13_0.<BackupTable>b__0(Stream x)
    at _3cxNetBackupAndRestore._3cxBackup.ZipDbTable(String table, Action`1 writeContent)
  16. GiannosC_3CX
    GiannosC_3CX Guest
    Hi There,
    Please could you (If those are on SP4 ) do the following steps?
    1) Put the system in Verbose mode
    2) Disable the scheduled backup
    3) Restart All 3CX Services including the Database
    4) Enable your scheduled backup
    5) Monitor and let us know if this happens again.
  17. GoPiTM
    May 15, 2015
    9
    Where is the Verbose mode in 15?
  18. GiannosC_3CX
    GiannosC_3CX Guest
    Hi @GoPiTM
    To enable the verbose option, you can go to Dashboard => Activity Log => Settings => and choose the Verbose option.
  19. GoPiTM
    May 15, 2015
    9
    The backup worked.
  20. GiannosC_3CX
    GiannosC_3CX Guest
    Hi GoPiTM,
    Please keep an eye on it and let us know if it happens again.
