Backup - Include contents of Firmware Folder
Discussion in '3CX Phone System - General' started by techdummy, Dec 22, 2017.
  1. techdummy
    techdummy New Member
    Sep 22, 2017
    182
    9
    I'm taking a backup of the 3CX v12.5, and I see there are a few things I can chose to ignore.
    If I don't check the option "Include contents of Firmware Folder", what will happen??
    I'm planning to restore the backup on to the v15.5.
    All the phones we are using will remain the same expect for the obvious client for windows.
    So, do I have to check "Include contents of Firmware Folder" during backup, or what happens if I don't?
    Thank you.
  2. cobaltit
    cobaltit Active Member
    Mar 22, 2012
    924
    147
    So if you check the box it includes the contents of the Firmware folder. If you don't check the box it doesn't. Is this a trick question?
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    420
    Hello @techdummy
    When you upgrade to V15.5 you will need to upgrade your phones to the supported version for V15.5. You can find the supported firmware for your phones here.
    If you include the option in your backup then firmware versions that were downloaded for V12.5 will be included in the backup but are not really necessary for V15.5 as new firmware will be downloaded for this version. It is up to you to include it or not.
