Backup issue
Discussion in '3CX Phone System - General' started by craigreilly, Oct 19, 2012.
  1. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    Anyone see this before? I noticed my automated backup hadn't run in a week.
    I tried to run it manually and get this.
    Windows 7 Pro.
  2. craigreilly
    Feb 1, 2012
    3,575
    305
    Quick solution. Went into Task Manager, selected to show processes for all users.
    It showed that 3cxBackup.exe was running under Admin. I am logged in as Admin, but it seems because the Task runs from task scheduler, it does not show up here.
    So, I terminated the process and backup is working again.
    So, the task was hanging. It was set to terminate - but after 3 days. I changed that down to 2 hours.
  3. 3CXfoxhallsolutions
    3CXfoxhallsolutions New Member
    Sep 8, 2012
    211
    Was the extended time due to you backing up the voice recording files Craig???
    I saw another case of a 3-day backup due to voice recording being included ... and suggested that either VR be sent to RAID or backed up with some other utility.
    best regards
  4. craigreilly
    Feb 1, 2012
    3,575
    305
    The backp had been running successfully since May.
    This is the first time this happened...
    The backup includes all files.
