Backup Location
Discussion in '3CX Phone System - General' started by Peter Bata, Jan 25, 2017.
  1. Peter Bata
    Dec 22, 2016
    12
    Never mind. I figured it out!
    Hello all. I am running 3CX version 15 on a Debian box. I have been accessing the Console via Chrome from a Windows 10 machine. For the longest time I have simply clicked on a bookmark that I created and presto I was presented with my dashboard.
    Long story short, I must have cleared my cache for one reason or another. I am now being asked for my login credentials. Of course, I have absolutely no recollection of what that might be. I had been making regular backups and I understand that I might be able to find those credentials in an XML file.
    Can anyone provide me with the path where my backups are located.
    Thank you
    Peter
    #1 Peter Bata, Jan 25, 2017
  2. cobaltit
    cobaltit Active Member
    Mar 22, 2012
    832
    127
    /var/lib/3cxpbx/Instance1/Data/Backups
  3. Peter Bata
    Dec 22, 2016
    12
    Thank you sir. Much appreciated. Peter
  4. Robert Drake
    Jan 30, 2017
    I have to change the local ip as I understand it I need to uninstall the debian and reinstall and use the backup file. In our windows version I thought the default location was deleted when the 3cx was removed. Where should I save the backup where it would be available on the reinstall?
  5. Taff3333
    Jan 18, 2017
    21
    6
    I have had to do the same process, save the back ups locally on the machine and you will be able to restore from these later.
    Duane
    Peter Bata likes this.
