Backup server
Discussion in '3CX Phone System - General' started by haywardi, Apr 19, 2011.
  1. haywardi
    Feb 27, 2011
    84
    Some advise please.
    After experiencing some problems with my main server a few days ago, I installed a new copy of 3CX on another server to keep the PBX running whilst I fixed the problems on the primary server.
    Thought this would be simple, but thats another story.
    However, now that I have the primary server running again, I would like to keep the installation of the backup installed on my other system just in case I need it again. However, each time I start the machine, 3CX is enabled and tries to log onto my SIP providers.
    Is there anyway to disable the functionality rather than remove the 3CX installation?
    Thanks in advance
    Iain
  2. countrycomp
    Dec 2, 2008
    53
    Set the 3CX services todisabled on the backup server.
  3. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    On the backup server set all of the 3CX services to not start automatically. Then create a batch file that starts them up. This way if you have a problem you can simply double-click an icon on the desktop to fire up the services and even restore a current configuration.
  4. leejor
    11,117
    329
    How do you deal with having two devices on the network, with the same IP, at the same time? I would assume that the second server would have to have the same IP (at some point) for devices to be able to register with it.
    Please excuse my ignorance as I don't normally work with servers.
  5. haywardi
    Feb 27, 2011
    84
    Hi Lee,
    Actually I would cheat! The pbx is the only app that requires an dedicated ip (everything else is name based) therefore the backup server can run on it's own ip until required. Then a simple change in the dhcp server to allocate the primary server ip address on reboot, job done.
    Iain
  6. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    not so good if you also run Exchnage server on the main server and have port forwarding setup on the router!
    maybe a workarond is to have two ips on the main server, one for other I.T services such as Exchnage and thne another IP for 3CX, all you do then is disable the second IP on the main server and enable it on the second server?
    hope this makes sence.
