Backup to google drive, 0 bytes
Discussion in '3CX Phone System - General' started by NChasTech, Nov 3, 2017.
  1. NChasTech
    Nov 3, 2017
    My manual backups work fine, but if I use the scheduler, I get 0 bytes on my backups. Forgive me so I am a total n00b here, how do I see why its failing and/or logs for the backup?
    Thanks for any help!
  2. daneke
    May 8, 2017
    46
    My Google backups work flawlessly manual or automated. Using Debian.
  3. danimal
    Apr 24, 2017
    19
    My backups fail also. I'm told its fixed in SP2. So, 3CX, you are saying go ahead and update to fix the problem, which by the way ..
    "Warning - this is a BETA Update. Some functionality might not be fully tested and can have bugs. BETA updates are not to be used in production environments. BETA Updates can not be reverted. However from a BETA Update, you can update this to the next beta or to the Release."
    Well I am in a production environment and I can't back up and you are telling me to install a beta version that can't be reverted.
    I expect better than this.
  4. NChasTech
    Nov 3, 2017
    One of the boxes with this issue is Debian and another is Windows, so I think its a 3CX issue.
