Backups and Licence
Discussion in '3CX Phone System - General' started by bell, Feb 12, 2015.
  1. bell
    Jul 30, 2014
    23
    I'm about to roll out a lot of small installs of 3CX so im not going to be using very powerful hardware, just an i3 with 4gb ram and a single hard drive.
    The PC's will be backing up configs nightly to external an external hard drive.
    Im also going to keep one machine built up with 3CX installed and unconfigured and unlicenced so in the event we have one fail it will be a quick swap and a restore of the config on the external drive.
    What im wondering is if the licence will transfer across without any issues being on different hardware. I've read that if the external IP remains the same there wont be any problems (which it will), just want to confirm that or ill need to look at other ways of getting it done.
  2. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,198
    188
    Without getting into the technical aspects of the license checking (it is more than just external IP)... you should be ok. Frequent changes to the environment for an existing license will cause a problem. As a fail-safe, if you have a 'lot' of small installs, you might want to think about buying an extra license for that spare box, or just having it but not activating it to use if need be.
  3. leejor
    10,869
    304
    As I understand it...it is the MAC address of the new NIC card that will be an issue when attempting to use the same licence. I believe that you then need to contact 3CX to have the licence "moved' to the new hardware.
  4. bell
    Jul 30, 2014
    23
    Okay thanks for that. Ill have to see if its worth while buying the additional licence or running them under the free licence for the time it takes to get the other up and running. Does anyone know if it will drop down from paid for to free licence or will stop working all together after import? I don't really want to test it and break something.
  5. cobaltit
    Mar 22, 2012
    1,198
    188
    If the license fails to activate it will drop down to the functionality/imitations of the free license.
