Bad Gateway 502 on Patton 4112 Gateway
Discussion in '3CX Phone System - General' started by pbagroup, Jul 16, 2009.
  1. pbagroup
    Jul 16, 2009
    Hi from Australia
    I have a working 3CX v7.1.7139.0 system with (2) VOIP providers that works well. I have purchased a Patton 4112 dual FXO box runing software version R5.3 2009-05-20 H323 SIP FXS FXO. I have added the PSTN gateway to the 3CS server and created a v5.x config file that loded into the 4112 OK.
    The 4112 is registered with the 3CX server with no problems.
    I have connected a PSTN line connected to FXO 0/0 and when I try make a call out via the 4112 FXO port I get the following error in the Server Activity Log
    21:36:30.031 [CM503003]: Call(38): Call to sip:84043701@192.168.1.4:5062 has failed; Cause: 502 Bad Gateway; from IP:192.168.1.4:5062
    Does anyone have any clues to point me in the right direction?
    Paul
  2. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    hello,
    you have installed the good file in the patton ? *
    do you try to create again the config file with 3cx, and import again ?
  3. pbagroup
    Jul 16, 2009
    Thanks for the prompt reply. Yeah we reset the Patton to factory defaults and reloaded the v5.x config from 3CX and it registered OK with the 3CX but we still get the bad gateway..
    Paul
  4. pbagroup
    Jul 16, 2009
    Problems fixed.. Found the PSTN cable to be faulty... Now we have dial tone and can make calls out.. But when someone calls in the Patton box answers the call and terminates it.
    Paul
  5. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    ths for the reply. just the cable :lol: .
    good continuation
  6. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    Have you set the default inbound route for the Patton to send incoming calls to?
    Without it set correctly the Patton will hang up incoming calls.
