badfetch
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, Aug 20, 2009.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    I keep getting a badfetch error when I try to use a database component. I've tried removing the variables and changing settings, but the error seems to broad to know what to try.
    Any help?
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    How are you filling the database component properties? Can you post a screenshot of the configuration dialog, or paste here the values you're using? Also, the exact error text you're getting will help us to know what's going on...
  3. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    This badfetch is coming back to haunt me... I can't seem to make database calls.
    Here's a screen shot of my component...
  4. VAD_Support
    Aug 6, 2009
    690
    Can you provide the error reported in 3CXIvrServer.log?
    Thanks.
  5. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Where is it located on windows 2003?
  6. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Here's the log.
    I had to replace the "http" text in this log with "_ttp" because the message board would not permit more than two urls in a message.
    2009/09/21 >>
    05:07:12.296|0224|.\PbxMedia\IVREngine.cpp(883):IvrService, IVREngine::RegisterLines(), Registering of lines...127.0.0.1:5060127.0.0.1:5060999[800,856][401,402][MakeCall]
    05:07:12.296|0224|.\PbxMedia\IVREngine.cpp(1036):IvrService, IVREngine::RegisterLines(), Registering of lines done.
    05:09:42.609|1152|(0):Error! Module '3CX.com.OSBinet'. Error ID 302. URL_ttp://localhost:5484/(S(wp1l3qmwx0xqvn45fpyncbes))/dr.aspx?dr=800&to=800&from=8019387712
    05:09:50.968|1152|.\api\VXItelImpl.cpp(148):IvrDll, VXItelImpl::Impl::IntrnTransfer(), Error! Error of 'From_8019387712_To_800_Menu_800_#0/45' session transferring to sip:856@127.0.0.1:5060. Status: NEAR_END_DISCONNECT. Transfer error. Session stopped
    05:10:00.437|3272|(0):Error! Module '3CX.com.OSBinet'. Error ID 219. URL_ttp://localhost:5484/(S(qsoe3rvwdyx50p55pue3o045))/CellsAgent_Debug_64/GetAgentPhone_MF_dbGetNumbersForProperty_DoIt.aspx?dataSource=&database=cellsagent.com&parameterCount=1&parameter_0=&password=8Trh76&server=TFS2%5CSQLEXPRESS&userName=cellsagent.comMethodGETError-500
    05:10:00.437|3272|(0):Error! Module '3CX.com.OSBinet'. Error ID 204. rc2
    05:10:00.437|3272|(0):Error! Module '3CX.com.vxi'. Error ID 203. uriGetAgentPhone_MF_dbGetNumbersForProperty_DoIt.aspx
    05:10:02.171|3272|.\api\VXItelImpl.cpp(148):IvrDll, VXItelImpl::Impl::IntrnTransfer(), Error! Error of 'From_8019387712_To_856_Menu_856_#1/46' session transferring to sip:856@127.0.0.1:5060. Status: NEAR_END_DISCONNECT. Transfer error. Session stopped
    07:07:08.640|0224|.\PbxMedia\IVREngine.cpp(883):IvrService, IVREngine::RegisterLines(), Registering of lines...127.0.0.1:5060127.0.0.1:5060999[800,856][401,402][MakeCall]
    07:07:08.640|0224|.\PbxMedia\IVREngine.cpp(1036):IvrService, IVREngine::RegisterLines(), Registering of lines done.
    07:08:43.640|0224|.\PbxMedia\IVREngine.cpp(883):IvrService, IVREngine::RegisterLines(), Registering of lines...127.0.0.1:5060127.0.0.1:5060999[800,856][401,402][MakeCall]
    07:08:43.640|0224|.\PbxMedia\IVREngine.cpp(1036):IvrService, IVREngine::RegisterLines(), Registering of lines done.
    07:09:00.015|4340|(0):Error! Module '3CX.com.OSBinet'. Error ID 302. URL_ttp://localhost:5484/(S(1lyc5mqbbqvbwtiexojtwiij))/dr.aspx?dr=800&to=800&from=8019387712
    07:09:06.734|4340|.\api\VXItelImpl.cpp(148):IvrDll, VXItelImpl::Impl::IntrnTransfer(), Error! Error of 'From_8019387712_To_800_Menu_800_#0/48' session transferring to sip:856@127.0.0.1:5060. Status: NEAR_END_DISCONNECT. Transfer error. Session stopped
    07:09:14.656|0772|(0):Error! Module '3CX.com.OSBinet'. Error ID 219. URL_ttp://localhost:5484/(S(ubvoqq55yrosa3qngrmrvnmk))/CellsAgent_Debug_66/GetAgentPhone_MF_dbGetNumbersForProperty_DoIt.aspx?dataSource=&database=cellsagent.com&parameterCount=1&parameter_0=100650&password=8Trh76&server=TFS2%5CSQLEXPRESS&userName=cellsagent.comMethodGETError-500
    07:09:14.656|0772|(0):Error! Module '3CX.com.OSBinet'. Error ID 204. rc2
    07:09:14.656|0772|(0):Error! Module '3CX.com.vxi'. Error ID 203. uriGetAgentPhone_MF_dbGetNumbersForProperty_DoIt.aspx
    07:09:16.406|0772|.\api\VXItelImpl.cpp(148):IvrDll, VXItelImpl::Impl::IntrnTransfer(), Error! Error of 'From_8019387712_To_856_Menu_856_#1/49' session transferring to sip:856@127.0.0.1:5060. Status: NEAR_END_DISCONNECT. Transfer error. Session stopped
    07:43:34.796|0224|.\PbxMedia\IVREngine.cpp(883):IvrService, IVREngine::RegisterLines(), Registering of lines...127.0.0.1:5060127.0.0.1:5060999[800,856][401,402][MakeCall]
    07:43:34.796|0224|.\PbxMedia\IVREngine.cpp(1036):IvrService, IVREngine::RegisterLines(), Registering of lines done.
    07:44:22.734|5040|(0):Error! Module '3CX.com.OSBinet'. Error ID 302. URL_ttp://localhost:5484/(S(qgvtij24utegib45erzimd45))/dr.aspx?dr=800&to=800&from=8019387712
    07:44:30.828|5040|.\api\VXItelImpl.cpp(148):IvrDll, VXItelImpl::Impl::IntrnTransfer(), Error! Error of 'From_8019387712_To_800_Menu_800_#0/51' session transferring to sip:856@127.0.0.1:5060. Status: NEAR_END_DISCONNECT. Transfer error. Session stopped
    07:44:38.609|5108|(0):Error! Module '3CX.com.OSBinet'. Error ID 219. URL_ttp://localhost:5484/(S(jsjtem45poaimi2fre5lra55))/CellsAgent_Debug_67/GetAgentPhone_MF_dbGetNumbersForProperty_DoIt.aspx?dataSource=&database=cellsagent.com&parameterCount=1&parameter_0=&password=8Trh76&server=TFS2%5CSQLEXPRESS&userName=cellsagent.comMethodGETError-500
    07:44:38.609|5108|(0):Error! Module '3CX.com.OSBinet'. Error ID 204. rc2
    07:44:38.609|5108|(0):Error! Module '3CX.com.vxi'. Error ID 203. uriGetAgentPhone_MF_dbGetNumbersForProperty_DoIt.aspx
    07:44:40.406|5108|.\api\VXItelImpl.cpp(148):IvrDll, VXItelImpl::Impl::IntrnTransfer(), Error! Error of 'From_8019387712_To_856_Menu_856_#1/52' session transferring to sip:856@127.0.0.1:5060. Status: NEAR_END_DISCONNECT. Transfer error. Session stopped
  7. VAD_Support
    Aug 6, 2009
    690
    It is usually under C:\Documents and Settings\All Users\Application Data\3CX\Data\Logs
  8. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    ok, I just posted the log above in my last message.
  9. VAD_Support
    Aug 6, 2009
    690
    This seems to be the problem related to the newline character in the SQL statement. Try removing that newline. We'll fix that in the next release.
