BadImageFormatException
Discussion in 'CRM / Helpdesk / App Integration' started by C.Koesling, Dec 12, 2016.
  1. C.Koesling
    Dec 12, 2016
    Hi everyone!
    I'm currently trying to build a ASP.NET web application that should implement features from the CallControl API.
    When referencing the 3cxpscomcpp2.dll however, I get a BadImageFormatException when I debug the app.
    I read the thread in which forum user Apereira discribed a similar problem (https://www.3cx.com/community/threads/error-using-omsamples.45436/) and tried to follow the steps that helped him, but to no end.
    The app is debugged on "any cpu", the .dll is referenced and set to local copy, I copied all .dll-files from the 3xc installation path to the debug folder.
    I'm quickly running out of ideas here. Does anyone have an idea where the problem might be?
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,677
    131
    Hi there,
    The BadImageFormatException is usually caused by an application running in 32 bits and the DLL is 64 bits or the other way around. The library "3cxpscomcpp2.dll" taken from the latest 3CX machine is x64. And it has a dependency on the library "sl.dll" which you also need. You can take these libraries from the 3CX installation directory. Ensure that you're getting them from the same 3CX server, and you don't have old DLLs from previous versions of 3CX.
    Kind regards.
    Ernesto.
