Bandwidth per minute
Discussion in '3CX Phone System - General' started by ilkeryildiz, Mar 12, 2007.
  1. ilkeryildiz
    Jan 7, 2007
    26
    Would like to know how much of bandwidth is used for per minute of call?
    "The volume that is transferred per minute is 1.2 MB (uncompressed, G.711,) or 0.4 MB (compressed, G.729)."
    is this true?
  2. 3CXsupport
    3CXsupport New Member
    Aug 21, 2006
    193
    The Norm uncompressed PCMU can take up to around 90kbps . a 64kbps payload with overhead.
    There are many 'VoIP Bandwith Calculators' online which can detail the expense in bandwith.
