Barge In
Discussion in '3CX Phone System - General' started by JamesG221, Mar 21, 2014.
  1. JamesG221
    Nov 4, 2013
    Does anyone know it it is possible barge into a call using the handset? Is there a dial code or does it have to be initiated from the soft phone?
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Not possible,
    this feature has been requested plenty of times.
