Basic Config for an IPCOMMS Sip Trunk
Discussion in '3CX Phone System - General' started by jmccrae, Jun 17, 2013.
  1. jmccrae
    Jun 17, 2013
    Good Day, I am setting up an IPCOMMS Sip Trunk per their instructions for 3CX and cannot get the trunk to register. Is there a configuration document of some sort or any guidance I can read up on. I am getting a 403 error during registration which tells me my config is busted somewhere.
    Cheers
    John
  2. jmccrae
    Jun 17, 2013
    Turned out to be some kind of keyboard error. Not sure how that happened. They are certainly rare. :D
    Tips for using IPCOMMS:
    1) Make sure you have enabled 3-way Auth in the general settings and use your assigned phone number as the value
    2) Ensure you don't have a trailing space in your password. <- this is where the keyboard error crept in.
    Cheers
    John
    Monroe likes this.
  3. leejor
    11,277
    360
    Those pesky spaces have a way of getting in there, unnoticed. It happens a lot when people cut and paste passwords.
