- Joined
- Sep 30, 2009
- Messages
- 41
- Reaction score
- 0
Hello All 3CXers...
I am a newbie, and have bunch of questions that appreciate your kind comments:
1) is 3CX capable of connecting to my modem (connected to my motherboard, and works, since I use it for receiving/sending faxes) to make calls? Does it have to be specific model or what? I want 3CX to be able to connect to this modem, so that extensions (local and remote) can make calls.
2) what ports must be forwarded from my router to 3cx machine (NATing) so that remote extensions work? This system is used in a country that VoIP is filtered all together, so can ports be changed?
3) can 3CX work on VPN connections?
My final goal is to benefit from my computer back home, and using 3CX, call locally through the modem on that machine, via my remote extensions, and save on international calls by making them local.
Your kind comments are appreciated.
Thank you!
Ali.
Thank you!
Ali.
