basic SIP echo test with 3CX
Discussion in 'Windows' started by caburt, Feb 24, 2010.
  1. caburt
    Feb 24, 2010
    Hi there,
    Is there a way I can use the 3CX phone out of the box to perform a SIP echo test?
    I need to do this to check I can use the ports it needs.
    The top google search for free SIP echos is as follows:
    http://www.voip-info.org/wiki/view/Phone+Numbers
    I am unable to key a SIP address in to the "iphone" interface of the phone. Perhaps there is another interface?
    This page shows a completely different interface, perhaps it is old
    http://blog.tmcnet.com/blog/tom-keating/voip/3cx-free-sip-softphone.asp
    I do not have a PBX or a VoIP service provider as is required by other soft phones such as Zoiper.
    best regards,
    TDG
