Been searching but cant find.
Discussion in '3CX Phone System - General' started by miraportuga, Aug 29, 2007.
  1. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Ok here's the thing. Like i said on other posts everything is working, inbound and outbound calls. Now, my father brought to my attention that he needs to check my PSTN provider voice mail to see if there are any messages there. To do this usually(with a phone connected directly to PSTN line) we dial *200. I would like to know if i can do the same thing but... with the phone connected to the SPA3102.
    Thank you
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    did you try it?
    it seems you need to just dial prefix+*200. For example, if outbound rule is "9" for this PSTN then you need to just dial "9*200"
    P.S. 3CX has a native voice mail subsystem, why don't you use it?
  3. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Yes i tried that, i get a busy signal after i do that
    And im not using the 3cx Voice mail system becouse my father prefers the other one, and... becouse 3cx still doesnt have Voice mail in portuguese :D hehe
    Thank you
    P.S. - Any more ideas ? :|
  4. Anonymous
    Anonymous Guest
    Set 3cx up with a outbound rule to dial the PSTN line on the SPA.
    Than when your dad dials eg 9 and *200 it will work as it is part of the DTMF string going to the PSTN.
  5. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    I have the system set like that, but i get a busy signal right after... just like i said up there :|
  6. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    Busy signal, usually from the SPA (and you can check by plugging phone directly into SPA "Line 1" port for a quick test), indicates an issue with the dial plan. Any outgoing calls on the SPA "Line 1" will be subject to the dial plan present. The SPA interprets anything beginning with a "*" as a command string for an option such as call forwarding, and its not matching the command you are sending. For my provider, Vonage, I just checked the local voicemail number and programmed it into speed dial. However, with some tweaking, you should be able to setup dial plan to send out that string upon receipt. Loads of fun!
  7. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Thanks... ill try that... :D
  8. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Well, not even after i added PSTN Voice mail number to speed dial... i cant dial from a phone connected to 3cx box. Guess my dad will have to Check voice mail on a old old phone i have here... lol
    Most probably something is wrong here and i cant see it.
    Thank you
