Beeps on the line
Discussion in '3CX Phone System - General' started by evdbovenkamp, May 31, 2007.
  1. evdbovenkamp
    May 31, 2007
    5
    When I call out (not tested yet with incoming) after a few seconds I hear (soft dtmf) beeps on my line. When I call 'around' the software directly to the provider I don't hear them.
    Anyone?
  2. Anonymous
    Anonymous Guest
    This beep has a fair few of us stumped.
    Normally the beeps are initiated with:
    - call waiting
    - registration/billing timers from VSP
    - message received
    to name a few.
    The odd thing is that it happens when you use the software and it does not happen when you do not use 3cx.
    Weird, I have no idea. Would like to be able to reproduce it but I can't (trust me i tried).
    So question time:
    - Who is your vsp?
    - Does the beep happen frequently, for example every minute etc.
    - What services do you have with your VSP (eg call waiting etc).
    - What IP phones do you use
    - What DTMF configuration do you use
  3. aorlando
    May 29, 2007
    27
    - Who is your vsp?
    www.vira.it -
    (Random Time..it can be 20 seconds, 2 minutes)
    No services -
    LinkSys SPA941-
    DTMF Tx Method: Auto
    No problem with LinkSYs SPA9000 or TrixBox as PBX
    Vira's got Cisco as PBX
  4. evdbovenkamp
    May 31, 2007
    5
    I have exactly the same experience!!
    None
    Linksys SPA942 (is this maybe the problem??)
    Aorlando has also a Linksys SPA.
  5. Anonymous
    Anonymous Guest
    Ok I think I got a handle on this (but that might be different tomorrow :)). First the problem is caused by the ATA, every time something does not happen as expected I see quotes like.
    This problem is not caused by 3cx and is not solved by TrixBox (well not really). Most likely (i might be wrong) is that the problem occurs on PSTN calls and not so much on VoIP calls.
    I got two theories:
    What you have is what can be called "Talk Off", what happens is, based upon the voice of the caller the frequencies fool the ATA to generate a DTMF.
    So there you have it, try to talk in a low voice (both you and the called person) and see if you get the beeps.
    Theory number two.
    Codecs..... I do believe that this problem does not happen when using G726 protocol. Most likely that was what you used on TrixBox or something like that.
    Now is there a fix......
    Well only a few things you can try, i do not know if they work.
    Set DTMF Tx Method to INFO
    Set DTMF Tx Mode to strict
    Keep in mind that if you get problems with getting the correct DTMF tones across to a sender (like banking or even using the IVR) you might have to change the DTMF TX Method back to auto or Inband. Inband+info is also an option you can try but not sure if your model has that.
    Good because LinkSys is Cisco :).
  6. aorlando
    May 29, 2007
    27
    This fix doesn't seem working.
    On my SPA941 as you said I defined
    DTMF Tx Method: Info
    but still beeps persist.
  7. Anonymous
    Anonymous Guest
    Bugger,
    Well the guys at 3cx might do some smarts with the software to make it stop.
    Lets see where they come back with.
  8. 3CXsupport
    3CXsupport New Member
    3CX Support
    Aug 21, 2006
    193
    We've tweaked the DTMF recognition module and loosened up the sensitivty which caused these instances of false detection. Some users were complaining of random DTMF strokes being mistakenly picked up.
    The new release will have this issue fixed which should be due for release before the end of this month.
  9. evdbovenkamp
    May 31, 2007
    5
    You are the best! I am looking forward to the new version!
    Thank you for your support!
    Erwin
  10. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Hi Erwin,
    for version 1928, problem can be partially solved by setting "DTMF Process AVT" to "no" in phone configuration. (advanced configuration - "Ext n" page)
    Hopefully, 941(942) also has this setting.
    Stepan
  11. giovanni0826
    Apr 6, 2007
    53
    Beeping
    did the beeps go away?
  12. Anonymous
    Anonymous Guest
    Re: Beeping
    It fixed the issue for me on my Linksys SPA942. However, when I call in and my AA picks up the line, I hear the beeps as well. Probablly the same setting needs to be changed in my gateway as well.
    Brian
  13. giovanni0826
    Apr 6, 2007
    53
    i believe the issue is with the PBX.
  14. Anonymous
    Anonymous Guest
    I believe you're right. When I call in from an outside line, I still hear the beep when misc audio/noise is picked up in the call.
    Brian
    http://www.jaydien.com
  15. giovanni0826
    Apr 6, 2007
    53
    System Beeps
    I've tested it on 2 different Windows Servers. Both have Windows Server 2003 R2 Standard OS but different hardware. Server 1 is a Pent III 1GIG RAM and NO BEEPS. Server 2 Pent 4 1GIG RAM and BEEPS. odd. any one know of motherboards with issues regarding 3cx?
  16. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,871
    169
    We have identified this and have made a fix. It will be in the next build which we should release next week if all goes well.
    Apologies for this.
  17. Anonymous
    Anonymous Guest
    Bummer, really it was such a good "undocumented" feature. It was the only thing that kept me awake when I was on the phone with the mother inlaw :lol:
    Every beep was translated into a "Hm Hm Yes Ma" :twisted:
  18. giovanni0826
    Apr 6, 2007
    53
    Beeps
    Exactly, for me it was the ex-wife. i would time my "FOUR LETTER WORDS," to coincide with every beep. :twisted: ... HE HATED IT!!!! :twisted:
  19. tcgmuc
    Mar 14, 2007
    59
    Hi Henk,
    perhaps the guys at 3CX can make a Button for "Mam
  20. Anonymous
    Anonymous Guest
