beronet 400 and 3cx
Discussion in '3CX Phone System - General' started by icomms, Jun 28, 2017.
  1. icomms
    Jun 28, 2017
    Hi We are located at 00350 internationally, and when we dial international numbers. Calls go out as 00350 then the international number. So we cant dial out on international. Also incoming calls locally shows an extra 0 at the beginning. Thoughts?
    Ta Tom
  2. Rory
    Dec 9, 2016
    17
    For the leading Zero. It most likely is your incoming number type.
    You could change your incoming dial plan to
    Dialplan ISDN --> SIP
    Source: 0(.*)
    See if that helps
