Best Linux Backup Method
Discussion in '3CX Phone System - General' started by ntnetzeband, Jan 17, 2018.
  1. ntnetzeband
    Jul 30, 2016
    65
    5
    We have a few instances installed on Windows Servers and they all run backups to a centralized share on our SAN and that works fine.
    We just set up a Linux server and are testing it to possibly convert in the future, however, I can't see a good way to run a backup either through command line or GUI to backup to this centralized share. When I try and do it through the GUI, it shows a "Specified Invalid Path" error. This server has full connectivity to this share, I can ping the server IP address and even created a symbolic link that worked fine but the link seems to break every few days.
    Does anyone have any recommendations? We do not want to back up only to this server in case the whole server fails, we lose back ups. That is why we back up to our SAN which has redundancy.
  2. jimbo59
    jimbo59 Member
    Nov 17, 2017
    357
    77
    Why not simple FTP as you are inside your own lan. From there you can move files as you see fit.
    Or you can backup locally and create a cron job to move the files. It's a standard linux installation.
    #2 jimbo59, Jan 17, 2018
  3. ntnetzeband
    Jul 30, 2016
    65
    5
    This was my backup thought but just didn't want to set up FTP if I didn't have to :)
    If we continue with Linux installs, we probably will end up using FTP but was hoping there was as easy a way as Windows installs to put in the file share name and leave it at that.
