Best Out of Box QoS
Discussion in '3CX Phone System - General' started by jonathanjohnsn, Jul 23, 2011.
  1. jonathanjohnsn
    Jul 3, 2010
    23
    I wanted to get the opinion of what people have found the best out of box QoS managed switches are. Anyone have any preferences? I am at a point where I want to improve my setup to improve some traffic issues I have.
    Thx
    Jonathan
  2. willow
    willow Member
    Mar 1, 2011
    471
    any switch that supports qos is a good start. netgear, extreme, and HP have been good switches for me. netgear on the low end, HP in the middle and extreme on the high end. all support qos out if the box.
  3. jr3151006
    jr3151006 New Member
    Jul 30, 2010
    155
    We have few computers/servers at office, we dont have Q.O.S on the switch but on the firewall to ensure network connectivity/bandwidth enough to SIP calls!
    * Our Switch (Cisco SFE2000P)
    * Our Internet Conneciton: ADSL 15M
    * Our Gateway: Linksys SPA400
  4. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Better replace the SPA-400 with router supporting QoS, you may still use it for PSTN trunks, etc., as a device in the LAN.
    The bottleneck is your Internet connection. I would recommend a small cost effective and powerful router like Mikrotik.
    Regards
