Solved Best path for re-iping 3CX Instances
Discussion in '3CX Phone System - General' started by xirgo, Nov 29, 2017.
  1. xirgo
    Nov 9, 2015
    22
    Good day,
    I'm about to start a project that will require me to re-ip (change the public static IP) of about 6 3CX Instances.
    The instances vary from V14 Cloud Instances to V15.5 (Linux and Windows).
    I will be doing some dry runs throughout the next few weeks to document the whole process however In the meanwhile I wanted to reach out to the people on this community to see if anyone had any tips or experiences they would like to share with me.
    What's the safest and best method for changing the public IP on 3CX instances? Will I need to relaunch new instances and restore from a backup or is there a more simple method to achieve what I'm about to set out to accomplish?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    5,514
    361
    Hello @xirgo
    The public ip's can be changed from the management console of the PBX without having to re-install the PBX. Navigate to settings / Network
    and set the the IP to Dynamic after your IP changes. Restart services and wait for the DNS to propagate if you are using a 3CX FQDN.
    Once it changes you can set it back to static again.
  3. xirgo
    Nov 9, 2015
    22
    Thank you @YiannisH_3CX for the information
    Is the same true on 3CX V14 Cloud Multi-tenant edition?
  4. StefanW
    Jun 2, 2009
    1,210
    85
    kindly allow me to say: backup, uninstall, deploy v15.5, restore
    Surely you dont want to run customers still on v14 nor do they.
    Still to answer your question, no V14 can not and just v15.5 SP2 lead this trick for its local interfaces...
