Best phone for easy provisioning.
Discussion in '3CX Phone System - General' started by David Rew, Mar 28, 2017.
  1. David Rew
    Mar 10, 2017
    8
    I know this will be subject to peoples views and they will be different, but I'm looking to roll out sites across the country with 150+ handsets, so in your view, which make of handset is the easiest to provision.
    The sites are for a DR solution so to need to be able to provision then to different instances of 3cx's hosted at the data center.
  2. MRM
    MRM
    Dec 21, 2016
    53
    Hi David Rew,
    As we cannot advise on what to buy for easy provisioning, what we can do is advise on the supported phones on this web link
    https://www.3cx.com/sip-phones/
    Good luck.
  3. David Rew
    Mar 10, 2017
    8
    Would still be interested in others experiences please.
  4. leejor
    11,293
    361
    If you are planning on auto-provisioning all of the sets, and it's assumed that there won't be any networking issues at different locations, then one (supported) set will be no more difficult to programme than another. It will just come down to set features, appearance and cost. If you plan on manually provisioning all or some of the sets, then that would narrow the field
  5. DSXDATA
    DSXDATA New Member
    Oct 20, 2015
    192
    66
    As said, if you are facile with DHCP option 66 then any supported brand will work fine. Otherwise, Yealink might be worth considering. They have a Zero Touch provisioning system that is flawless.
  6. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    47
    I'm a huge Yealink fan. Easiest setup with multiple ways of provisioning. You can ship unopened boxes and it'll provision / program itself when plugged in (no need for option66 using the yealink rps)
  7. computatech
    Oct 21, 2016
    20
    Yealink gets my vote, i've played about with Snom 760 and Yealink T41 and T42, I would recommend using yealinks, snom phones don't always work in my experience can be a bit troublesome at times.
  8. rdb35
    Apr 5, 2017
    I like the Yealink phones as well. Has anyone provisioned the CP860 on Google Cloud?
