Best practice for user with multiple phones
Discussion in '3CX Phone System - General' started by dotnetfabrik, Mar 24, 2011.
  1. dotnetfabrik
    Feb 24, 2011
    31
    Hi together,
    I'm asking for your experience: consider having an user who has two office seats (e.g. one in the dev-office and one in the management-office). Needless to say, that he does not carry his phone from one office to the other and back again.
    So he has two phone-devices (let's say: a GXP2000 and a GXP2120).
    This is where my question begins:
    - should I create two different extensions in 3CX (afaik the only way to make provisioning with the different phone models work)?
    or
    - should I put them both on one extension?
    What would you do?
    Thanksalot!
    Sascha
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Simply put them both on one extension. They will both ring simultaniously.
  3. dotnetfabrik
    Feb 24, 2011
    31
    Hi Mark,
    thanks for your answer, but what about provisioning?
    We would have two different phone-types on the same account?
  4. leejor
    10,781
    286
    I suppose you could provision them manually if you wanted to. But any sort of auto-provision should be based on the MAC address or IP of the device(s), not just the extension number.
  5. dotnetfabrik
    Feb 24, 2011
    31
    Yes, but I can only put one single phone into one single extension-item.
    Therefore, auto-provisioning is not possible?!
  6. dannybrook
    Feb 24, 2010
    43
    Thats correct, only one auto-generated provisioning template per extension. What you need to do is open the folder which contains the provisioning templates, and make a copy of both files associated with the MAC address of handset 1, the second copy should be named using the MAC address of handset 2. All 3CX does is auto-generate the provisioning files, if you wanted, you could make your own files and as long as they match the proper format, your phone will load the file.
  7. jnz
    jnz
    Aug 5, 2010
    62
    To keep it simple why not create a ring group for 2 different extensions and have the ring group number be the persons extension number.... make both extensions ring at the same time. If the person is a member of another queue or ring group add both extensions into the queue or group. This way it will be a simple set up......
    The only draw back to this would be in the use of the 3cx assistant it would be hard to use because of multiple extensions.
