Best router for remote site
Discussion in 'Windows' started by aftermarket, Jun 19, 2010.
  1. aftermarket
    May 13, 2009
    84
    just upgraded to a belkin n1 adsl router and it doesnt work with our cisco phones for voip, so we've resorted back to our old buggy router which crashes all the time. we were wondering if anyone could recommend a router which they know works with 3cx when at a remote site as well as cisco 504g phones. thanks
    10,360
    226
    Most newer routers should have no problem at a remote site. In many cases you won't even need to set up port forwarding, with each set having it's own, unique, port number. What specific issue do you have with the Belkin router? Is it a model that has known issues with VoIP?
  3. mfm
    mfm Active Member
    Mar 4, 2010
    641
    In our experience, we have found out that the cheaper the router the better it seems to work with SIP, many routers with SIP helpers tend to cause issues, so try and get one with little or no SIP capabilites at all.
  4. mhanson
    mhanson New Member
    Nov 6, 2008
    186
    I have had the same experience as Mark. For every Sonic Wall I see fail, I see about 50 Linksys routers costing around 40 dollars work flawlessly.
  5. aftermarket
    May 13, 2009
    84
    thanks for that, we've just gone and bought a cheap router and taken back our expensive one. we've found that if we use the 3cx tunnel proxy program the phones work alot better, just annoying that we cant connect them directly
  6. zman574
    Jun 24, 2010
    57
    I litterly had the same issue with the same phones until about an hour ago. I purchased a WRN2000V2 and had to open the NAT up on the router to get more than one phone to work at a remote site.... its a bit tricky at first but once you get it up it will work great. I can help you with settings if you need it, I am testing 4 more of these routers tomorrow all referbs purchased online check out tiger direct and you should be able to get some of these referbs..... they do limit you to 5 at time but with next day air it was less than 210.00 US for 5 of them. Let me know if you need this info and I will post it for you.
  7. mylove4life
    mylove4life New Member
    Jan 7, 2010
    165
    I have installed Sonicwall routers/firewalls for years and never had a issue with VOIP. What problem are you seeing with them?
  8. mhanson
    mhanson New Member
    Nov 6, 2008
    186
    I have seen around 10-15 different sites where they had an existing Sonicwall, and with remote sites, there is just weird issues with the NAT/Forwarding. They will forward every single port that is needed, and traffic will either make it through on the wrong port, or not at all. The "Proper" settings just dont cut it for them. I'm sure this is some form of fix, as some can make it work, but Sonicwall doesn't seem to know it themselves.
  9. galal202
    galal202 New Member
    Jun 23, 2008
    235
    LinkSys AM200 works nice at remote side
    also dlink
    The Secret in full vcone nat
  10. aftermarket
    May 13, 2009
    84
    thanks, we've ended up going for a netgear one and it seems to work well.......however we've introduced a second phone to the remote site and it registers ok but theres no audio either way, any ideas? do i need to open mor ports?
  11. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    Is it an FSV318?
  12. leejor
    10,360
    226
    A second phone at a site can cause router confusion if the same voice ports are being re-used with a device on a second IP. I've had that problem on occasion.
  13. aftermarket
    May 13, 2009
    84
    how did you get round it?
