Best Router?
Discussion in '3CX Phone System - General' started by seanbts, Oct 18, 2010.
  1. seanbts
    Oct 12, 2010
    34
    Hi All,
    We currently us a sonic wall tz170 in our office which is causing us issues with 3rd, I'm looking at replacing the tz170 but am looking for recommendations that will work fine with 3cx, any recommendations?
    Cheers
    11,073
    323
    May time the basic routers (read inexpensive) work just as well as the pricey ones. Of course if there are specific features ( types of wireless) you are looking for, then you'll pay more
  3. seanbts
    Oct 12, 2010
    34
    Don't really need any mad features, just looking for makes that will work with 3GS and do full cone nat
  4. sunstate
    sunstate Member
    Dec 16, 2009
    257
    http://www.3cx.com/forums/what-s-your-favorite-firewall-15225.html
  5. seanbts
    Oct 12, 2010
    34
    Thanks but it says I'm not authorised to read that forum?
  6. sunstate
    sunstate Member
    Dec 16, 2009
    257
    Oh, sorry. Didn't notice that was in the Partner forum. Here are the recommendations that came out of that thread:
    Cisco ASA55xx
    Dlink DFL-xxx
    pfSense
    Mikrotik 450G
    For pfSense, there were a couple hardware recommendations as well.
    Supermicro's 1u barebone (Intel Atom)
    Netgate appliance
    I was one of the pfSense recommendations. The majority of the time I use Netgate's 3 eth appliance. The only time I use different hardware with a full install is when I need more then 3 interfaces and/or more power.
    http://store.netgate.com/Firewalls-C2.aspx
  7. seanbts
    Oct 12, 2010
    34
    Great thanks for this info
  8. seanbts
    Oct 12, 2010
    34
    Hi Again,
    Actually is there any way to get the tz170 to work, when I run the firewall test I get responses with translations?
  9. danoh
    Aug 18, 2010
    56
    Endian is a good free linux-based firewall. http://www.endian.com
    Support SIP proxy'ing too if you need it.
  10. semn
    Jan 25, 2010
    21
    I using Cisco ASA5505 without any issue. i definitely recommended an ASA55xx box it's very stable and i don't had any issues 3cx related.
  11. redorum
    Mar 2, 2009
    Danoh - how did you get 3cx to work through endian? You don't get 1 way audio? What version of endian (2.4.1?)
  12. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    The MikroTik line is quite excellent. You can start with a 750G or upgrade to a 450G. All of our satellite offices are on the 450G. Use EoIP for the phones if you have any need to bridge locations. No overhead, easy setup.
