best VoIP Provider
Discussion in '3CX Phone System - General' started by mylove4life, Sep 16, 2011.
  1. mylove4life
    mylove4life New Member
    Jan 7, 2010
    165
    Hi all, what do you guys use for your provider in the USA? I have Callcentric now, but can't use fax and I get a lot of busy signals... Looking to move... Thanks
  2. Knossos
    Sep 17, 2011
    Nexvortex.
    Excellent service.
  3. willow
    willow Member
    Mar 1, 2011
    471
    voip.ms is fantastic.
  4. tsteffens
    Jul 14, 2011
    85
    I have used voipo, voip.ms and now callcentric. I had the worst quality issues with voipo, voip.ms was good but support was lacking, callcentric has the best service and support team is extremely responsive.
  5. runneranu
    Sep 19, 2011
    8
    @tsteffens: I am replying to this post because i am trying to set up/install 3cx.
    can you please read this and help? appreciate your help in advance.
    I have a call centric account with a 777 number. says a phone is not registered. i got into this to set up a google voice account from outside the US.
    i have downloaded 3cx multiple time but upon installation i am not getting the option to configue a SIP server. can you please tell me what i should download and what if any i am doing wrong.
    thanks, a
  6. tsteffens
    Jul 14, 2011
    85
    for starters, I would start your own thread, you aren't going to get any help piggybacking on another thread completely unrelated to your issues.
  7. mylove4life
    Jan 7, 2010
    165
    Thanks for the options guys, I'll take a look at them and see if they can do faxing as well.
  8. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    Flowroute provides great service (plus T38), NexVortex was the worst.
  9. tqhx
    Apr 3, 2010
    28
    Great luck with Broadvox here.
