Best way to configure Weather Closure
Discussion in 'Call Flow Designer' started by Flash99, Dec 5, 2017.
  1. Flash99
    Aug 3, 2017
    83
    7
    We currently have a flow for each office with Business Hours, After Hours and Holidays
    What would be the best way to add "Weather Closure" ?
    Since the system is used in several different locations it needs to be something that we can set per location and not system wide as Holidays
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,361
    109
    Hello @Flash99,
    You can save the information in a database for example, so the CFD app can check the information from there and behave accordingly depending on that.
    Kind regards.
