Best way to provide an "On Call" set up for out of hours
Discussion in '3CX Phone System - General' started by verta, Aug 20, 2013.
  1. verta
    Aug 19, 2013
    11
    Hi All,
    I hope you can help.
    We have a set of three engineers who rotate their out of hours on-call duty on a weekly basis. Previously we had an Asterisk-based phone system and we simply created a ring group (mapped to a certain DDI) which dialled mobile numbers on a prioritized hunt. I can see a way to get 3CX to do similar - I can create the ring group with prioritized hunt, but I can't seem to put in external numbers to ring - only extensions, and then forward to one number.
    Is there a better way to do what I'm trying to achieve?
    All help is greatly appreciated.
    Thanks,
    Verta.
  2. bardissi
    bardissi Member
    Jan 31, 2012
    318
    Yes there is a better way to do this
    http://voiptoys.com/products/334-3cx-on-call-manager-by-voiptoys.aspx
  3. verta
    Aug 19, 2013
    11
    Thanks for the link bardissi. I think that may be a little expensive so we will have to stick with what we have at the moment (ring extension for 1 second then forward to single external number).
  4. oedlan
    Nov 3, 2008
    18
    Couldn't you create extra, "faux" extensions for the engineers and set it to call their mobile numbers after 1 second?
  5. verta
    Aug 19, 2013
    11
    I didn't think of that - great idea. I'll do that instead! Thanks oedlan.
  6. oedlan
    Nov 3, 2008
    18
    No problem :D
    Just glad I could help
