Best way to provision two lines (separate providers)
Discussion in '3CX Phone System - General' started by infused, Aug 7, 2017.
  1. infused
    Oct 17, 2013
    19
    So we have a conference phone provisioned via 3CX. On the second line, we need to configure it by another provider. I assume if 3CX ever re-provisions the phone, or updates it, then the second line config would be lost?
    What's the best way to do this so they can co-exist?
    The reason for this if you're wondering is it's a shared conference phone between two companies sharing an office.
  2. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,601
    242
    Typically reprovisioing the phone only changes the settings for account 1 so you can manually configure account 2 and it should stick.
  3. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,250
    202
    As above
