Beta Version 3.0.2295.0 - Backup rule doesn't work
Discussion in '3CX Phone System - General' started by aorlando, Jun 19, 2007.
  1. aorlando
    May 29, 2007
    27
    Installed the beta version (Version3.0.2295.0)
    as upgrade from last.
    Configured for every prefix the outbound rules with a backup rule
    for Patton Smartnode ISDN (verified);
    turning off the internet , the calls are not routed to backup rule
    (Patton im my situation) !!
    Any tips ??
    10:02:12.569 ClientRegs::eek:nFailure [CM113006] Registration of sip:voipline2@sip.vira.it has failed; reason=Request Timeout
    10:02:12.569 ClientRegs::eek:nRequestRetry [CM113008] Registration attempt for Ln:10000@Skypho is scheduled in 120 sec.
    10:02:12.569 ClientRegs::eek:nFailure [CM113010] Next registration will be attempted in 10 minutes
    10:02:12.569 ClientRegs::eek:nFailure [CM113006] Registration of sip:voipline2@voip.eutelia.it has failed; reason=Request Timeout
    10:02:06.663 CallConf::Rejected [CM103005] Call(16) is rejected: Destination is not answering
    10:02:06.663 StratInOut::eek:nCancel [CM104008] Call(16): Call from Ext.123 to mycellphone@terminated; cause: 408 Request Timeout; internal
    10:01:40.381 ExtLine::Register [CM110004] Send registration for "voipline1"<sip:voipline1@sip.vira.it>
    10:01:40.381 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10001' device='Vira'
    10:01:40.350 ExtLine::Register [CM110004] Send registration for "voipline2"<sip:voipline2@voip.eutelia.it>
    10:01:40.350 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10000' device='Skypho'
    10:01:40.209 CallMgr::failResolveExtIp [CM200001] Failed to resolve external IP!
    10:01:40.209 StunClient::process [CM215001] STUN failed to resolve external IP using server 83.211.227.28
    10:01:37.147 StunClient::process [CM115001] Send initial STUN request to 83.211.227.28
    10:01:37.038 StunClient::process [CM215001] STUN failed to resolve external IP using server 83.211.227.28
    10:01:34.381 MediaServerReporting::STUN [MS101003] Call(16) Ln:10000@Skypho: Possible firewall problem. Address mapping failed on STUN server 83.211.227.26:3478 for local address ":9000"
    10:01:33.975 StunClient::process [CM115001] Send initial STUN request to 83.211.227.28
    10:01:33.866 StunClient::process [CM215001] STUN failed to resolve external IP using server 83.211.227.28
    10:01:30.803 StunClient::process [CM115001] Send initial STUN request to 83.211.227.28
    10:01:30.694 StunClient::process [CM215001] STUN failed to resolve external IP using server 83.211.227.28
    10:01:28.194 CallConf::eek:nIncoming [CM103002] Call(16): Incoming call from 123 (Ext.123) to sip:mycellphone@voip-pc.taborelli.it
    10:01:07.178 CallConf::Rejected [CM103005] Call(15) is rejected: Destination is not answering
    10:01:07.178 StratInOut::eek:nCancel [CM104008] Call(15): Call from Ext.123 to :mycellphone terminated; cause: 408 Request Timeout; internal
    10:00:34.959 MediaServerReporting::STUN [MS101003] Call(15) Ln:10000@Skypho: Possible firewall problem. Address mapping failed on STUN server 83.211.227.26:3478 for local address ":9006"
    10:00:28.772 CallConf::eek:nIncoming [CM103002] Call(15): Incoming call from 123 (Ext.123) to sip:mycellphone@voip-pc.taborelli.it
    10:00:22.412 CallConf::Rejected [CM103005] Call(14) is rejected: Destination is not answering
    10:00:22.412 StratInOut::eek:nCancel [CM104008] Call(14): Call from Ext.123 to mycellphone terminated; cause: 408 Request Timeout; internal
    09:59:50.146 MediaServerReporting::STUN [MS101003] Call(14) Ln:10000@Skypho: Possible firewall problem. Address mapping failed on STUN server 83.211.227.26:3478 for local address ":9004"
    09:59:43.912 CallConf::eek:nIncoming [CM103002] Call(14): Incoming call from 123 (Ext.123) to sip::mycellphone@voip-pc.taborelli.it
    Code:
  2. aorlando
    May 29, 2007
    27
    I'm the only one with this problem ??
  3. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    Hmmm... Give me some time to test this tomorrow in the test network, and I will come back to you with an answer.
  4. aorlando
    May 29, 2007
    27
    News ???
    The upgrade didn't give me any error.
    I tried to reinstall the upgrade of beta version a second time and still backup rule don't work.
    Sincerely I don't know where I can have failed in the configuration
    of the rules: it appears so "basic".
  5. 3CXsupport
    3CXsupport New Member
    Aug 21, 2006
    193
    Can you kindly try against the updated version (2328) ?
    http://www.3cx.com/downloads/3cxphonesystem31_2328.exe
    There have been some improvements specifically with the backup rule you mention.
  6. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi Site admin,
    Unable to download. Please check.
  7. aorlando
    May 29, 2007
    27
    Upgrading to the new beta version "outbound backup rules" now are working :)
    Great !!!
    09:07:23.710 StratInOut::eek:nHangUp [CM104007] Call(2): Call from Ext.123 to mycellphone has been terminated by Ext.123; cause: CANCEL; from IP:192.168.1.40
    09:07:15.352 CallConf::eek:nProvisional [CM103003] Call(2): Ln:10002@Patton4552 is ringing
    09:06:42.108 MediaServerReporting::STUN [MS101003] Call(2) Ln:10000@Skypho: Possible firewall problem. Address mapping failed on STUN server 83.211.227.27:3478 for local address ":9000"
    09:06:35.819 CallConf::eek:nIncoming [CM103002] Call(2): Incoming call from 123 (Ext.123) to sip:mycellphone@voip-pc.taborelli.it
